Does anyone know where I can get the files to 3-D print a phone case or does anyone have that they can share?
I’m looking for a lot of different ones, especially the F21 Pro
I know u probably don’t want this but it doesn’t hurt to try you have an option of using fiver to hire someone to create cad file for you
I don’t mind paying but it probably requires you to send them a phone for testing and measurements
U can get a cheap thing that helps with measurements and send them the measurements these tools that help with measurements are very precise
Like what tool?
If thats true. I would do the same for then exalt. As there doesn’t seem to be any cases on the market for the exalt.
I was wondering if it would be possible to 3D print a body of a phone.
Which phone?
Cat
I’d want a new body designed.
Most definitely but the parts would need to be extremely precise
