Android Auto Emulator
if you want to see if your device/rom works with android auto and you dont want to go to your car /sombody elses car all the time you can emulate android auto on your computer
  1. unzip this file and put it somewher on your windows computer
  2. open android auto on your phone and click version and then tap it again many times and okay the promtp for dev options
  3. click on the 3 lines at the top right corner and click start head unit server
  4. click on the batch script in the folder i linked below and android auto will open on your computer
This is dhu?
For some reason stuck on the screen once I connect the phone even after turning on head unit
do you have the latest version of androdi auto. is it installed in /priv-app or at leat a stub there
what device is this. is adb connected
ADB is connected
And it’s a kosher device that works in a car android auto
I don’t know if this is necessary or not but did you run,
adb forward tcp:5277 tcp:5277?
This the official desktop-head-unit? I don’t know how it looks on Windows.
Shouldn’t be like this, but the only troubleshooting step I can think of:
Unplug phone and open a terminal:
adb kill-server
Then plug in and try again.
Also, like @MJZ said, you can try wireless.
Run the program before turning on headunit, it will say press any key to to continue.
Turn on headunit and then press key on pc.
That worked for me
you have to start head unit server before starting the emulator
Tried that
Which phone are you trying?
If it’s a kosher phone, it probably won’t support ADB
if it’s a kosher phone, it WON’T support ADB
You can clarify that with @anonymousfliphones
It’s a kosher phone but me as the admin can control the ADB ability
Oh
In that case its not that secure. @ars18 can break it
Megalife Phone Hacked?! Yes! - General - JTech Forums
