Android Auto F21 Pro
How can I use android auto on a Qin f21 pro without having the Google app? When I’m connecting it to the car it it says that need to download the Google app first
Yes but there are ways to block it while keeping aa
Check the forums
Edit: or as @walt_cohn said below use a stub
I actually use one, funny I forgot
Just beware it doesn’t work on higher android versions but you should be find for a stock based f21
Use a stub
What’s a stub? Or how do I check the forums?
thanks
You check the forums by searching
A stub is an apk you install which tricks the system into thinking Google is installed when it isn’t
Where can I get a stub for the Google app?
Where do I check the forums on my phone?
thanks
