Mind sharing how?
android auto or play services?
expanded the system.img and put in all google services files
Would it be possible to make a magisk module that could do this automatically.
PS what did you add to the system.img, just play services and Android auto or a lot of Google apps as well?
a lot of google apps, basically core from opengapps
I would share the rom but i have really slow upload speeds
Why don’t you try by adding the minimum amount of Google apps you need (if you want more you can add them later).
core is the necessary apps
The Android Auto specifically is slow or the whole phone slowed down?
not sure, I was only using it to test android auto and it was slow, I didn’t really try using it for much else
how did you do it
made the system partition larger and added the necessary google files
How do i make the system partion larger?
termux
whats the command
ro2rw module
Could you explain?
google it. ro2rw magisk module. do a maximum expansion
If someone wants to make a clear step by step guide how to do it it would be greatly appreciated.
I made a guide but the site won’t let me post it
maybe I can’t make more than one topic a day?
