Any update?
Still cant post it
what error are you getting?
“An error occurred: You are not permitted to view the requested resource.”
I think it means that an error occurred and that I’m not permitted to view the requested resource
Tried refreshing?
Got it, apparently I can’t create guides, so I categorized it as general
does this module also work on the tcl?
no, the cat has the google services framework in product, so this module puts android auto in /product/priv-app, most phones have it in system. Do you have google play services on your tcl? if you do, check where gsf is and I’ll make a module that works with the tcl
I have a tcl with play services but I don’t really understand what you want me to look for.
no i do not, are you able to create a guide how you put android auto on the tcl?
Full Google play services slows down the tcl a lot. It would have to be a very minimal and lightweight situation if you want it to work normally
Would it work with microG?
I use a litegapps magisk module and this is where gsf is stored. System, product, private app, and the apk is in a folder in there.
You need signature spoofing. Have you got that?
How do I add that?
I’m trying to build it all into the super
Its hard and I never did it before you need patch certain files. my plan is to pull those files from the kosher Rom and put it in the super hopefully after yt
The kosher ROM has MicroG? For what?
Ok. Will look into it as well
I think Darth wanted to put play service dependent apps but didn’t end up,
zygisk+lsposed, if you want to build it into the super you need to patch some framework files with nanodroid
