Beginners Questions
which tcl has brom?
All of them besides the tracfone/walmart-family/totalwireless and the new 4058G
What is the difference between sp and TWRP
SP Flash Tool and TWRP are two different tools used for modifying Android devices, but they serve different purposes.
1. SP Flash Tool (Smart Phone Flash Tool)
  • What it does:
    • Used for flashing firmware (ROMs) directly to the device’s storage (e.g., bootloader, system, recovery partitions).
    • Works at a low level, often in “Download Mode” (not regular recovery mode).
    • Mostly used for MediaTek (MTK) chipset devices.
  • When to use it:
    • When your phone is bricked (won’t boot).
    • To install a stock ROM (official firmware).
    • To unbrick a device or fix boot loops.
    • To flash partitions that TWRP can’t modify (like preloader).
  • How it works:
    • Requires a PC (Windows).
    • Needs USB drivers and a scatter file (partition layout).
    • Often used when the phone is completely dead (no recovery/boot).
  • Risks:
    • Can hard-brick the device if used incorrectly.
    • Requires exact firmware for your device model.
2. TWRP (Team Win Recovery Project)
  • What it does:
    • A custom recovery that replaces the stock recovery.
    • Used for flashing custom ROMs, kernels, mods, backups, and wiping partitions.
    • Works in a graphical touch-based interface (easier for beginners).
  • When to use it:
    • To install custom ROMs (LineageOS, Pixel Experience, etc.).
    • To root your device (Magisk).
    • To backup and restore your system (Nandroid backup).
    • To wipe data/cache/dalvik without a full reset.
  • How it works:
    • Boots into recovery mode (not fastboot/download mode).
    • Doesn’t always need a PC (can flash files from SD card/internal storage).
    • Must be unlocked bootloader to install.
  • Risks:
    • Can cause boot loops if flashing incompatible files.
    • Some devices may lose warranty if bootloader is unlocked.
Key Differences
Feature SP Flash Tool TWRP
Purpose Flashing stock firmware Flashing custom ROMs/modifications
Works on Mostly MediaTek devices Any device with unlocked bootloader
Interface PC-based (Windows) Touch-based recovery on device
Brick Recovery Can fix hard bricks Only works if recovery is accessible
Partition Access Full access (even preloader) Limited to boot, system, data, etc.
Ease of Use More complex (requires scatter file) Easier for beginners
Which One Should You Use?
  • Use SP Flash Tool if:
    • Your phone is dead/bricked.
    • You need to restore stock firmware.
    • You have a MediaTek device and no TWRP support.
  • Use TWRP if:
    • You want to install custom ROMs, root, or make backups.
    • Your phone still boots to recovery/fastboot.
    • You have a Qualcomm/Exynos device (SP Flash Tool is mostly for MTK).
Final Tip
  • SP Flash Tool is like a “factory reset” tool (deep-level flashing).
  • TWRP is like a “Swiss Army knife” for modding (user-friendly customization).
One is a app on your device and one is a tool on your PC. Both for flashing and more
an app is a program that runs on your device, a module tweaks something on your device
Nice.
Very clearly explained, and well-formatted.
Which bot wrote that up?
Where’s the topic I couldn’t find it
What is Magisk Patcher?
It’s part of the magisk app. It patches the boot.img (and for some phones, the recovery.img) to give super user permissions to the magisk app and allows magisk to grant super user permissions to other apps, it also installs a stub magisk app.
Just to add on, you can then flash the patched boot.img to that or another phone.
6 posts were split to a new topic: Qin F21 Pro & TIQ Mini M5 Stuck in Fastboot Mode
I would like to get my feet wet in regards to editing ROM’s. What’s a good tool to start with?
I used CRB, it’s pretty simple to use
There are issues using that with techloq, is there any alternative to avoid the hassle?
I’ve never used this, but in the tools link on top of the page there is this Sixo Android Partitions & ISO Image Tool | sisik which apparently can unpack system images for editing
Can it make super inches?
i see now it doesnt work with super images.
I saw this after our messages.
Your machine is set up, lemme know how you like crb :slight_smile:
Cool. This guy made Bugjaeger!
I prefer termux, but that’s a great app.
