After you put lineage on your device you can flash play services on from recovery, I think you need to do it before you boot the system though
Is it possible to run magisk modules without being rooted?
No
No, how do u plan on running them without magisk, magisk is root?
most magisk modules would need root if you were to do them manually
or you can just do a factory rest then add them
Beginner Question:
What in the world is happening in this thread?
Is there a limit to making threads? I made one earlier and can’t seem to make another one now
I unlocked my bootloader today to install a custom rom I got a message that now my phone can be accessible to hackers… is this something to be nervous about, should I be worried?
Is this the reason not to download banking apps?
I wouldn’t recommend downloading any banking apps on one of these phones because there is no encryption like Samsung has
Explain?
all the on brand smartphones have a “firewall” to not allow hackers into the phones while the not like qin and tiq etc dont (dont know about cat though)
What is the difference between a module and an app?
What is the difference between a ROM and a “stock firmware”?
ROM is what contains the OS. But it can be custom rom. Stock firmware is what the phone originally comes with.
stock rom - stock firmware
custom rom - custom software
afwall+
huh???
Firewall for rooted phones.
the rooting it is not the issue the problem is that basic phones and chinese phones are missing this firewall that regular smartphones have
