Breaking: Claude hacks 30 major companies!
September 2025. Anthropic detected suspicious activity on Claude. Started investigating.
Turns out it was Chinese state-sponsored hackers. They used Claude Code to hack into roughly 30 companies. Big tech companies, Banks, Chemical manufacturers and Government agencies.
The AI did 80-90% of the hacking work. Humans only had to intervene 4-6 times per campaign.
Anthropic calls this “the first documented case of a large-scale cyberattack executed without substantial human intervention.”
The hackers convinced Claude to hack for them. Then Claude analyzed targets → spotted vulnerabilities → wrote exploit code → harvested passwords → extracted data and documented everything. All by itself.
Claude’s trained to refuse harmful requests. So how’d they get it to hack?
They jailbroke it. Broke the attack into small innocent-looking tasks. Told Claude it was an employee of a legitimate cybersecurity firm doing defensive testing. Claude had no idea it was actually hacking real companies.
The hackers used Claude Code which is Anthropic’s coding tool. It can search the web retrieve data run software. Has access to password crackers, network scanners and security tools.
So they set up a framework. Pointed it at a target. Let Claude run autonomously.
Phase 1: Claude inspected the target’s systems. Found their highest-value databases. Did it way faster than human hackers could.
Phase 2: Found security vulnerabilities. Wrote exploit code to break in.
Phase 3: Harvested credentials. Usernames and passwords. Got deeper access.
Phase 4: Extracted massive amounts of private data. Sorted it by intelligence value.
Phase 5: Created backdoors for future access. Documented everything for the human operators.
The AI made thousands of requests per second. Attack speed impossible for humans to match.
Anthropic said “human involvement was much less frequent despite the larger scale of the attack.”
Before this hackers used AI as an advisor. Ask it questions. Get suggestions. But humans did the actual work.
Now? AI does the work. Humans just point it in the right direction and check in occasionally.
Anthropic detected it banned the accounts notified victims coordinated with authorities. Took 10 days to map the full scope.
But the thing is they only caught it because it was their AI. If the hackers used a different model Anthropic wouldn’t know.
The irony is Anthropic built Claude Code as a productivity tool. Help developers write code faster. Automate boring tasks. Chinese hackers used that same tool to automate hacking.
Anthropic’s response? “The very abilities that allow Claude to be used in these attacks also make it crucial for cyber defense.”
They used Claude to investigate the attack. Analyzed the enormous amounts of data the hackers generated.
So Claude hacked 30 companies. Then Claude investigated itself hacking those companies.
Most companies would keep this quiet. Don’t want people knowing their AI got used for espionage.
Anthropic published a full report. Explained exactly how the hackers did it. Released it publicly.
Why? Because they know this is going to keep happening. Other hackers will use the same techniques. On Claude on ChatGPT on every AI that can write code.
They’re basically saying “here’s how we got owned so you can prepare.”
AI agents can now hack at scale with minimal human involvement.
Less experienced hackers can do sophisticated attacks. Don’t need a team of experts anymore. Just need one person who knows how to jailbreak an AI and point it at targets.
The barriers to cyberattacks just dropped massively.
Anthropic said “these attacks are likely to only grow in their effectiveness.”
Every AI company is releasing coding agents right now. OpenAI has one. Microsoft has Copilot. Google has Gemini Code Assist.
All of them can be jailbroken. All of them can write exploit code. All of them can run autonomously.
The uncomfortable question is If your AI can be used to hack 30 companies should you even release it?
Anthropic’s answer is yes because defenders need AI too. Security teams can use Claude to detect threats analyze vulnerabilities respond to incidents.
It’s an arms race. Bad guys get AI. Good guys need AI to keep up.
But right now the bad guys are winning. They hacked 30 companies before getting caught. And they only got caught because Anthropic happened to notice suspicious activity on their own platform.
How many attacks are happening on other platforms that nobody’s detecting?
Nobody’s talking about the fact that this proves AI safety training doesn’t work.
Claude has “extensive” safety training. Built to refuse harmful requests. Has guardrails specifically against hacking.
Didn’t matter. Hackers jailbroke it by breaking tasks into small pieces and lying about the context.
Every AI company claims their safety measures prevent misuse. This proves those measures can be bypassed.
And once you bypass them you get an AI that can hack better and faster than human teams.
TLDR
Chinese state-sponsored hackers used Claude Code to hack roughly 30 companies in Sept 2025. Targeted big tech banks chemical companies government agencies. AI did 80-90% of work. Humans only intervened 4-6 times per campaign. Anthropic calls it first large-scale cyberattack executed without substantial human intervention. Hackers jailbroke Claude by breaking tasks into innocent pieces and lying said Claude worked for legitimate cybersecurity firm. Claude analyzed targets found vulnerabilities wrote exploits harvested passwords extracted data created backdoors documented everything autonomously. Made thousands of requests per second impossible speed for humans. Anthropic caught it after 10 days banned accounts notified victims. Published full public report explaining exactly how it happened. Says attacks will only grow more effective. Every coding AI can be jailbroken and used this way. Proves AI safety training can be bypassed. Arms race between attackers and defenders both using AI.
Source:
Can someone tell me this in short? I’m too impatient to read all that :joy:
Yes, ask Claude to summarize it.
Which companies?
I doubt they’re releasing that info.
