ars18
August 19, 2025, 8:53pm
1
Dunno if this will help anyone, but today I captured an ota link to inspect firmware. Need usb debugging, but no root necessary.
Linux:
adb logcat | grep -i 'http'
Windows:
adb logcat | findstr /i http
Go to system updates and search for update, press ctrl+c on the terminal when it starts downloading.
Take your output and dump it into an ai agent, ask it to find the update link. Or, ya know, you could sift through it yourself.
Should be able to download the firmware from that link.
I was thinking maybe someone would do this for the Kyoceras.
Use Payload Dumper Go to extract the firmware once downloaded.
ys770
August 19, 2025, 9:09pm
2
You can unzip it in WinRAR to see all the partitions
ars18
August 19, 2025, 9:11pm
3
You can unzip a payload.bin in WinRAR?
I’ve always used payload dumper go
ys770
August 19, 2025, 9:12pm
4
Maybe it downloads in different formats for othr phones, but for the TCL updates WinRAR worked
ars18
August 19, 2025, 9:16pm
5
I’m not to familiar with the Kyoceras.. but if TAG made custom firmware for them, and stock firmware is not online, I believe they must have started here…
Which Kyocera phone does TAG do this for? Does it have fastboot (before they do their process)?
ars18
August 19, 2025, 9:56pm
6
For example, I just did this for the E4810
That’s the only Kyocera phone I have. No fastboot as far as I’m aware, but I don’t know much about these.
Seems to have edl though.
There is source code online somewhere
ars18
August 19, 2025, 10:03pm
8
Some source. Maybe some kernels. Someone posted a link a while back.
Not firmware.
ars18
August 19, 2025, 10:04pm
10
I’d have to look into it. Never used it. Has anyone ever rooted these phones?
I used it for orbic but you need the correct firehose
ars18
August 19, 2025, 10:08pm
12
I’m assuming those are not available
ars18
August 19, 2025, 10:43pm
13
wonder if firehose can be extracted from verizon upgrade assistant…
Is that what Purifone did?
ars18
August 19, 2025, 11:38pm
15
No idea
Qualcomm stuff is all new to me, aside from OnePlus devices.
ars18
August 20, 2025, 1:04am
16
Tried installing it. All I was able to extract was fastboot drivers.
If I was actually able to run the exe, I might find something more… Maybe in tmp folders.
Anyway, the program does not run normally…
ars18
August 20, 2025, 6:06pm
17
This is another option for extracting if you don’t have a pc:
Payload Dumper App for Android. Extract boot.img or any other partitions (images) from OTA.zip or payload.bin without PC without root on Android
ars18
August 21, 2025, 4:11pm
18
Here is a firmware link for E4810 for example:
https://cdn2.vzwdm.com/Kyocera_E4810_1.402VZ_1.502VZ.bin
Their server is:
If the firmware for other phones are on this server, you can play around with the path.
ars18
August 21, 2025, 7:23pm
20
What firmware do you guys want
Currently running for E4810 and E4811
Can you do anything with it?
Is there any way to flash anything?
