I think I did, but will try again.
ars18
67
Tried pcapdroid?
Next best thing would be router level…
Similar.
Used HTTP Toolkit.
Also uses a VPN to capture the phones traffic.
ars18
71
Depends on the router. Would need to be able to view query logs.
Or you can set a custom DNS server and view them there.
But thats for domains.
I have that already.
I need URL’s, and what are the requests that the updater has to make.
ars18
73
If these are the servers:
Then the OTA zips would just be a path added to that url.
Not according to ChatGPT, which analyzed the APK.
It also analyzed the servers responses to a bunch of URL’s I tried.
ars18
76
Two things.
I skimmed through your ai convo, and just so you know, the Firehose will almost certainly not be in the update packages.
Aside from that, it doesn’t make sense to me that those are the update servers, but the otas are not on a path a of that url.
Also, how did you extract the APK without root?
Whats the big deal?
How many apps do you want that can do that?
ars18
78
I dunno, I guess I’m just so used to having root.
Upload the APK?
ars18
80
Put on drive? Download doesn’t work
ars18
82
You are correct.
<string name="config_fih_verify_referer">http://ota-filesite.oss-cn-hangzhou.aliyuncs.com</string>
<string name="config_ota_server_url">https://ota-us.fihcloud.com/</string>
Second one is the OTA server
Weird one
