Claude AI
How often does Claude go down?
btw UTC is 4 hours ahead of EDT for those that want to reference the 2
Yeah, I just tried signing into Claude for a job g.ai said Claude would do best, and I couldn’t.
Its back up now
@ars18 what did you do?
He got stuck at a traffic light, so he had Claude Code try to reverse engineer a few Kyoceras, but he was using so many tokens that it crashed Anthropics infrastructure.
He’s inside their servers though, so he’s working on getting everything back up.
Services restored. I had a backup.
Believe me i know of his traffic lights. :sob:
The other day he had a traffic light and we … - censored.
How’s Mythos?
Did you give yourself access to it?
I am mythos.
People prompt me and I send it to glm.
I am trying to upgrade to the $200 per month Claude plan but its not working
Is claude payments down?
it won’t go through
@ars18 can you push it through? :joy:
Sure one sec
U using sonnet and need the $200 plan?!
Btw, I know you did your taxes, but you should have claimed Claude for a deduction.
I just changed some things server side. Try again.
No Opus
I am not paying for Claude - work is - and that would be next year
and its on a company card so its already automatically a deduction
Thanks, it went through
How many tokens do I get per 5 hour period on the $200 plan?
Never mind I got the answer
WOW! Claude Code
Now that I used Claude Code CLI I can personally tell you that its a thousand times better then gemini
