Claude AI
Identifying dirty pipe vulnerability exploit sounds sus to them
First of all it’s not dirty pipe. Secondly they have no problem discussing cve’s.
Also, I checked and it’s insane to the next level!!! Should really go to tech stuff thread but whatever.
Check it out:
Almost every single Linux distro (basically every one) was vulnerable to this for years. This is a simple python script with just a few lines that gets you privilege escalation. Any server that wasn’t updated in the last day… There’s a lot of fun that many here can enjoy (@ars18 :winking_face_with_tongue:) but we obviously won’t since AI says it’s unethical
MAXED OUT THE MAX 20 X PLAN
I thought that wasn’t possible
Oh yes it is. They just introduced a cache timeout that drastically increases token usage.
Yea. Somehow I’m fifnishing my tokens after 2 prompts from the $20 plan. Insane, Worse in terms of rate limitting than any other companies free quota
They reduced it from 1hr to 5 minutes. That means that if you go to the bathroom your entire context memory gets reprocessed. They also are reducing rate limits during peak hours pretty drastically
Well I guess I’m gonna have to do a rush order from now on :wink:
Its annoying because every five minutes it says compressing
Is there a plan for more money? even $1k per month that has a bigger context window and longer cache and doesn’t max you out?
are you on the latest version of claude code?
think so
 API Error: Claude Code is unable to respond to this request, which appears
      to violate our Usage Policy (https://www.anthropic.com/legal/aup). This
     request triggered cyber-related safeguards. To request an adjustment
     pursuant to our Cyber Verification Program based on how you use Claude,
     fill out https://claude.com/form/cyber-use-case?token=oMoGso4jLm2-Aks8jYpW
     -ySHnM5GLeNIRIf6hoZ7_DtiIFM3g69vO06rxyhFaIQhOaAdpdbTTjHJJmOu1yhBwGAIUz--KE
     JMHAvcML1Tqkl-FS3c_RBj3UAgiqID9RE7oduwDvvNMQ. To learn more about the
     program or provide feedback, visit o… Please double press esc to edit your
      last message or start a new session for Claude Code to assist with a
     different task. If you are seeing this refusal repeatedly, try running
     /model claude-sonnet-4-20250514 to switch models.
:sob::sob: Just trying to play with the latest Linux privilege escalation vulnerability (dirty frag crazy!!) which I don’t understand enough to mess around with and it won’t let me
Edit: opus 4.6 isn’t as restrictive. /model won’t show it. Use /model claude-opus-4-6
Paying $200 a month for should guarantee a smooth experience, but the performance remains sluggish even during off-peak hours. I expected the lower server load at night to result in better speeds, yet the value just isn’t there. Has anyone else on this tier found a way to actually get the consistent performance we’re paying for?
How can I give claude code permission once for all it should not ask before any bash command etc. and wait till I respond?
claude – dangerously skip permssions or something like that
Ask it
I assume that it’s in a sandboxed environment?
Because otherwise that would be a very stupid idea.
When ever it asks I don’t look what it is doing anyway
