Thats what I tried.
do you have techloq?
Is there anyway to use CRB Android kitchen with techloq based upon not having the ability to enable WSL?
Is there any work around with techloq?
You can use Mio kitchen a crb alternative.
I never used techloq, and iām pretty sure they would, but do they block hyper-v?
If enough people are interested, I can theoretically make vmās (filtered to google drive links allowed only, for uploading and downloading projects) with crb installed that you can access with your browser.
Would not be free though, there are costs.
Did this for someone with techloq and they allowed my website.
Why would that help it work by uploading the project?
not sure what ya mean
it doesnāt allow it to run I donāt think what your saying would solve the issue
Here ya go:
I saw on that other thread you were having issues?
Were you successful at the end?
I didnāt end up spending much time on it.
Iām not very familiar on building a super.img, so if I unpack a super and edit the product system or vendor I have to rebuild them. What format do I use? Android Raw or Sparse or one of the other formats? Also then when building the super do I use Sparse, Raw or Sparse +LZ4 or Raw +LZ4? If someone could explain the main differences between the different formats thatād be great. Iām using CRB Kitchen.
Just flash the system in fastbootd its a lot easier. Regarding your question Iām not sure what I do
Yeah, I need to build the super.img to flash phones I just wasnāt exactly sure which format to use.
I think raw is used while working with the project, and sparse is for production.
Itās the difference in file size/compression.
If I recall correctly.
not sure why but okay
bricked my tcl that way, i modified with fx or mt pulled the super with neutron recovery or with the dd command and flashed in regular fastboot for qin and fastbootd for tcl
i didnāt
I am editing a super in crb, but for some reason the output of some of the partitions in the new super have ext instead of just img which is messing things up. Any fix?
