CRB Kitchen and Modding ROMs
Would probabley be able to figure out. But I only need it because crb is not installing. I will try again before I bother you.
I have crb installed on Windows, nothing works.
it works great on windows but if you have techloq it wont work because they block WSL
I have NetFree.
Don’t know if it blocks WSL.
I’m in middle of testing CRB on a
Windows To Go installation, and it seems to working.
During the setup when I try to toggle crb wsl distro I get an error message that an error occurred while importing distro. Any ideas?
Did you enable WSL just now during setup?
Enabled then I restarted then tried.
Don’t what those are.
When I toggled it it installed
Oh, just realized still in wsl setup take a look
Virtual machine platform I have because I have wsa.
I modded a system partition with CRB kitchen, and after I flashed it, the device would boot to fastboot.
I then tried just unpacking and repacking it with CRB without making any modifications, and after flashing it still boots to fastboot.
I’m flashing with mtk client.
Any idea what the problem might be?
its enabled.
try flashing with fastboot
Someone told me it doesn’t work for under Android 10.
Anyone know anything about that?
Any alternative tools for unpacking and repacking system images that works with the bin files that mtk client generates?
It doesn’t actually have a functioning fastboot, just has a screen that says that its in fastboot.
Its not a phone.
Its a Timkoo-like device.
In the folder with crb.exe there’s a folder called wsl. In that folder there’s a folder called crb. Delete the crb folder and try importing the distro again
Anyone?
I think it works to rename the bin to IMG, so any tool that works with Android 8 IMG files would work, but I still don’t have such a tool that can repack it.
I tried but I’m getting same error.
Do you think I didn’t try what it says to do?
