Is it possible to soft brick a device that has TWRP?
Because I can’t get it to boot normally, into brom, or recovery/TWRP.
did you use the ro2rw module too make it bigger to fit everything in because i am running into the same issue on the qin
I didn’t use any modules, I haven’t been able to install any apps, including the Magisk app.
I sorta have brom.
Mtk client shows that its in brom, goes through most of the process of connecting, but at some point just stops, and won’t finish connecting.
If all you need is Sai then you could replace a different app with sai without unpacking the super. I had once did that using Android utility.
How did I not think of that?
But anyways, right now thats irrelevant, I first need to unbrick.
Preloader - Status: Waiting for PreLoader VCOM, please reconnect mobile to brom mode
Preloader - CPU: MT6753()
Preloader - HW version: 0x0
Preloader - WDT: 0x10212000
Preloader - Uart: 0x11002000
Preloader - Brom payload addr: 0x100a00
Preloader - DA payload addr: 0x201000
Preloader - CQ_DMA addr: 0x10217c00
Preloader - Var1: 0x28
Preloader - Disabling Watchdog...
Preloader - HW code: 0x337
Preloader - Target config: 0x0
Preloader - SBC enabled: False
Preloader - SLA enabled: False
Preloader - DAA enabled: False
Preloader - SWJTAG enabled: False
Preloader - EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: False
Preloader - Root cert required: False
Preloader - Mem read auth: False
Preloader - Mem write auth: False
Preloader - Cmd 0xC8 blocked: False
Preloader - Get Target info
Preloader - BROM mode detected.
Preloader - HW subcode: 0x8a00
Preloader - HW Ver: 0xca00
Preloader - SW Ver: 0x0
Preloader - ME_ID: A146C08ECF2013B36BCBABD74E5690C4
Preloader - Jumping to 0x200000
Preloader - Jumping to 0x200000: ok.
Detected preloader: /home/demo/mtkclient/mtkclient/Loader/Preloader/0699_preloader_c767_8111h_xxa1_39_o1_7D734924C1.bin
None
At that point it stops there, and the GUI stays on the device connecting screen.
Anyone have a solution?
Why dont you try following this guide - WWR-MTK: A Guide to Creating a Full Device Backup Using SP Flash Tool to get a full ROM backup?
I already have a backup of every partition.
What does that help me if I can’t flash it with mtk client?
If you have a scatter file, (which you can get using that guide) you can flash it with sp flash tool
Anyone have experience with Mtk Meta Utility?
Copilot says it might help me with my zach.
I believe it’s called Android utility nowadays. The tool is referenced above.
