Discussion for: How to Use ADB Wireless Debugging Without USB
https://www.jtechforums.org/t/how-to-use-adb-wireless-debugging-without-usb/1322
I have a Kyocera that presumably something is wrong with the motherboard, and it doesn’t recognize when plugged into PC.
Anyway I can use ADB over wifi without initially plugging it in?
U should be able to but maybe try a different cable
How?
It is a phone problem. I tried many cables that work fine in other devices.
Im pretty sure adb over wifi works only on phones android 11 and above unless you have the extreme+ i do not think it will work
Why would it work on the extreme+?
I just thought it was above android 11 not confirmed do u know what android version it is running
What model number is it?
e4_1_?
Kyocera e4811
Probably Android 9 or 10.
The e4810 is 9, and the e4830 is 10.
I don’t think any of the Kyocera flips are past 10.
Get the Sonim Xp3plus!
Endorsed by @Dev-in-the-BM_2.0!
why there is not a good mouse that works on it yet?
True, I almost forgot about it because I’m so used to using my Bluetooth mouse.
But both MATVT and C9 should work on the Xp3Plus 5G, although so far thats only נוגע if you use T-mobile or any of their MVNO’s.
