Dumbdroid / Dumber OS On The Tiq Mini M5 (Comments)
do you by any Chance have empty VBMATE.img for the m5 ?
I have the TIQ with dumber OS with US Mobile T-Mobile I set up the right APN and everything works besides sending MMS did anyone have this before?
@Yidish
Turns out it was a APN thing. But non of the ones us mobile gave me helped (spent 50 minutes with them on the phone).
Turns out I have reset resetting network settings a random APN showed up which I wrote down and added it manually and it works.
Can you post the APN
Important set MNC to 240. It won’t let you save as 260.
If you want your speaker phone (on phone calls) to work you need to toggle the bottom setting in the picture to off.
By default it will be on. When I had it in and turned on speaker while on a call nothing happened.
