Fidelity app on devices without Play Integrity (Qin F21 Pro)
I tried downloading version 30.1 and it was nothing downloading from GitHub do you have any tips how to download it from GitHub
Direct download link
https://github.com/topjohnwu/Magisk/releases/download/v30.1/Magisk-v30.1.apk
Any tips had to upgrade to version 30.1 cuz I’m downloading it and when I’m trying to install it it’s saying installation failed am I meant to uninstall magisk and just install the 30.1 version or is there something else I’m meant to do thanks again for your help
Try installing it with SAI 4.5.apk.
It should tell you the reason the install is failing.
It’s not allowing me to install version 30.1 I even tried sai
It just allowed me to add the version and RCS messages just started working but Google integrity is still not there so I’m assuming that’s the reason why Fidelity won’t work any clue how to get Google integrity to work so do I need delete the Play store and readd it maybe or is there an easy add-on thanks
Post can’t be empty…
Which version should I use 4.0 or 4.1
Of what
Tricky Adaon
I downloaded version 4.1 and play store is still not verified can it be that I need super user access
Version 4.1 just got deleted I have to do 4.0
You have to open the webui and set the the keybox
Then reboot
Set to what?
How do I open webui
In magisk. Press the action button for tricky store.
Also yes select from denylist.
Reboot
Look at the picture I posted.
What should I press
That’s weird, you should have like my screenshot below.
Did you reboot after flashing the modules?
No when I did it self deleted
