Sorry, don’t know what the issue is.
Reboot is a must
Reboot is a must
What is GPT topic?
Just got certified it worked what you told me
Nice enjoy
Fidelity working?
If it stops working you’ll have to set another keybox.
Did you set the denylist in magisk and the denylist in tricky?
Do that, clear fidelity data, and try again.
How do I set it I may have set it wrong
I denied fidelity in magisk was I also meant to deny play services
i can download banking apps on my qin and they work even though play store isnt certifiedand im not using magisk i just replaced the build.prop so maybe fidelity will work. i used gapps
the only wierd thing on mine is that even though all google apps work some none google apps that require play services (sms backup and zmanim…) wont work unless installed from the play store but otherwise everything seems to work
Fidelity still doesn’t work do you have any idea why Google Play store is verified is there anything more I’m meant to do?
You said you’re not using tricky store… Only edited build.prop
Can’t help
I do have tricky store installed is there another way for it to work
Dunno, try setting the security patch too.
Where did you download fidelity from?
Play store
I dunno sorry
