Fig Core
If you can actually fully block it from launching anywhere other than AA sounds great. Launcher would be a great addition
Yes, ifw already confirmed working exactly as you described.
Trying an overlay now to replace the Android manifest for maps, to see if I can hide it from the launcher
Can overlays overlay the Manifest? I’d be surprised
I’d suggest just patching the smali where the launcher displays installed apps to skip over maps. No need to build anything custom
Yeah, that might be above my pay grade. Maybe someone else can do it here
Finding out now. Probably not but did not want to decompile now
Did not work. Trying with maps as a system app now
Did not work, tried patching the APK manually but could not get rid of the icon even though I removed the launcher intent.
It’s in the manifest
I know. I removed it.
Just gonna leave it the way it is. It doesn’t open with ifw rules placed. Good enough for me.
Ever use lawn chair as a launcher for the qin? Looks nice and works great, and it’s open source. The only thing thats annoying about it is that pressing the keypad doesn’t dial numbers
Didn’t try any other launchers because of the nightmare I figure the d-pad is.
Not dialing numbers is a pretty annoying issue.
Right, but since it’s open source it can probably be fixed. Trying to work on that
It would probably ruin my sanity seeing as I only know basics of Android app development (if even that).
I wonder if we can use dumbdroid lineage patches for trebuchet. It works pretty nice, but android 14.
Whats that
lineage os launcher
https://www.apkmirror.com/apk/lineageos/trebuchet-4/
Want me to upload dumbdroids version? It was made for the qin f21 pro and doov r77
minimum sdk version will be too high for android 11
EDIT: Here ya go - https://drive.google.com/file/d/1IKsl1yqUwfAyUe3GWTvdfeR-9sPdVGSN/view?usp=sharing
I use nova launcher on the qin. You can use the dPad and it types into the search bar.
You can dial numbers?
this is how it looks when you dial
Better then nothing I guess
Code doesn’t work anymore
ani one with the new one?
thanks!
