I have a brand new Fig Mini F45 II. The battery life is terrible (on both batteries), especially during phone calls — it drains very fast.
Is this normal for this phone, or could there be an issue?
Any ideas or suggestions?
Why dont you call fig or walk into a fig store and ask.
I bought it and live in Israel
The seller dossent know to tell me if that how it is or its diffictive
How long does it typically last? 1 day? 1/2 day?
I’ve been tracking my battery performance and noticed a significant difference depending on my usage:
Light Usage: If I only make a few short calls, the battery easily lasts the whole day (until around 1:00 AM).
Heavy Usage: If I spend a lot of time on calls, the battery life is cut in half. like 2pm
the calls kill my battery
I would say that sounds normal. From my experience typically with regular usage I don’t think you can get much more than a day out of them.
The big fig just has 500ma more and lasts two days with a bigger screen
I think the F45 has a 1450mah battery and the F52 has a 2200mah battery. I don’t know why the F52 last longer because like you said it does have a bigger screen.
I don’t know anything about the fig but generally battery capacity is a small part of it. Besides the big screen and small screen it also depends heavily on how bloated it is, and some hardware specs like how many nanometers the network modem and CPU is etc. I stopped looking at capacity after having experience with lower capacity lasting longer then higher capacity sometimes.
Is there anyware else people talk more about the fig?
