Do I need to be connected to the internet?
No
Just wanted to let everyone know I was able to get my TCL flip 4058E software version QK6V ( Canada version ) rooted. Not sure where it would be appropriate to put this information so do what you will with this information. As a disclaimer this worked for me, but I cannot guarantee this is a safe method or it will work for you.
On windows 11 I had issues with installing the drivers. I came across a post where I had to disable memory integrity in core isolation settings. I would not recommend doing this on your main machine because when I tried to re enable memory integrity it wouldnāt allow me to. Regardless, autobooter.exe worked.
Next, the default neutron.img [v2024.06.10b] will soft brick the device. Do not use this one. I managed to get it to work with this image from the github repository issues ( IMG TCL FLIP 4058E Ā· Issue #16 Ā· neutronscott/flip2 Ā· GitHub ). This image itself its not made for the software verison QK6V, however it works with it. I havenāt run into any problems. Waze works, F-droid, and aurora store works. (I can not guarantee the safety of this img however neutronscott wrote that he would add it to the build sequence in 2024 ) I hope this information helps anyone else trying to root their Canadian TCL flip. I would also like to thank all the people who helped me walking me through the process of using neutronscott software.
Happy you figured it all out.
I also had to do that, what is it?
I belive if you update your drivers you wonāt need to.
I have no idea, but my drivers and everything as far as I know were all updated so I donāt know. Windows 11 is dodgy so its hard to say. Iām surprised I wasnāt able to make it work on any of my linux machines. Iām also curious if I factory reset my computer if iāll still be able to use adb like is the mtk drivers just for putting it into fastboot or is it required for adb as well?
adb doesnāt use mtk drivers, only flashing does
Iām happy benefit works for you and other ppl for me itās unreliable.
What? When? Where?
I donāt have a password setā¦
Also all the stuff is available on the forums
Itās not asking me for a password.
Maybe you have an account it wants you to log into?
Is it a kosher phone?
everything is possible, and we donāt unfilter phones hereā¦
