This is a factory-signed stock firmware that I managed to obtain.
Adds support for VoLTE (4G calling) on Israeli networks (some carriers may not work, but the vast majority do; currently only 019 Mobile is known not to work). [including HOT Mobile! According to reports from users)
Google Services included.
Locked bootloader! No need to unlock — just flash. You may need to use Format All & Download (which also flashes the IMEI).
According to reports from users, acssebility service don’t crashed
Based on my initial tests, it doesn’t kill background apps — for example, WhatsApp keeps receiving notifications consistently. I haven’t fully verified this yet.
Need to work 100% fix on old devices&new devices - no sound conflicts, but, right now, I didn’t check it
Of course, a locked bootloader plus Google Services means it’s also compatible with FRP protection for MDM filters such as Kdroid… and it will likely work (if I understood @kdroidFilter plans correctly) even with Kdroid version 1!
To support me, help promote the purchase of the new Qin F25, and say thanks
for my various community contributions,
you can purchase this firmware for $10.
