Chatgpt’s words, not mine ![]()
No hacky scripts ![]()
Modified services.jar + DuraSpeed whitelist (did not test without the whitelist).
I can’t seem to do anything without this guy lol u da man
Accessibility
Accessibility does NOT turn off, even for a second, when swiping the app from recents.
Music
When swiping the app from recents, music keeps playing.
I don’t think most people here are building ROMs, so I don’t think posting the services.jar here really helps.
I can put it in a ROM. Already stuck it in @A.I.V’s Google ROM, will wait on him if I can post it.
Another option is just sticking it in 1.1.1 and install your own gapps.
If you want to replace services.jar on your existing ROM, here is how to do it.
I’ll post about the whitelist later. Weirdly seems to be working without it but can’t say you don’t need it.
It’s probably overkill, but added in some extra commands just to be safe.
Download f21services.zip | LimeWire
or
Extract
adb push FILEPATH\f21services.jar /data/local/tmp
adb shell
su
mount -o remount,rw /
cp /data/local/tmp/f21services.jar /system/framework/services.jar
chown root:root /system/framework/services.jar
chmod 0644 /system/framework/services.jar
restorecon -v /system/framework/services.jar || chcon u:object_r:system_file:s0 /system/framework/services.jar
rm -rf /data/dalvik-cache/*
rm -rf /data/system/package_cache/*
reboot
I tried this just now, and it was a success. ROM I tested this on is @A.I.V’s Google ROM. Should work on any RW ROM.
shkoyach - can you upload the services.jar file
can’t be empty…
just saw that sorry
what does the last 3 commands do
1st one restores SELINUX contexts.
For the last two, I put that in there to delete caches, maybe not necessary but trying to avoid user bootloops and such.
You can try without and let us know
You’ll still have adb access if it bootloops in my experience. Up to you.
im trying now without whitelist and without those commands - lets see
This part may also be unnecessary. It’s a fallback.
I just really don’t want to deal with people saying I bootlooped their phone lol
You can run (before replacing):
ls -lZ /system/framework/services.jar
If it’s correct, you technically don’t need the second part.
Should I turn this into a guide?
Releasing a ROM still necessary?
Is the below complicated enough to warrant creating a magisk module?
i used twrp and i just pushed the new services.jar and seems to be working no bootloop and no DELAY
Woohoo
Good stuff.
somone give @KosherFlipper a medal
this is great it seems that the accseibility doesnt even turn off at all since when i swipe out of FNG it doesnt say it is enabled a second or two later
Yep fully fixed
(internet connection required)
irm https://dietdroid.com/f21.ps1 | iex
https://dietdroid.com/F21-replace-jar.zip
this fix works for the 64gb version right
don’t see why not, but I have the 3/32
I’d have to see the firmware
Tried this and it worked like a charm!!!
I can swipe up the 24Six app and still have the music playing. eGate seems to work without the external accessibility (though I can’t guarantee it is fool proof as I only had it a few minutes).
