Cool
Warning
The new services.jar seems to have a bug that blocks adb install.
Installing apk’s on the phone itself works.
Performing Streamed Install adb.exe: failed to install C:\Users\jhjhjhj\Downloads\in.krosbits.musicolet_6.6_build400-40000_minAPI16(arm64-v8a)(nodpi)_apkmirror.com.apk: Error: adb install not allowed 1!!
@KosherFlipper said he will patch later, then I will update.
i was able to use adb install just fine
i tried it 3 times and no issues
Interesting. Me and someone else both had this issue.
I tried on a fresh install
Not sure what you are trying to say
Hopefully someone else will try. Anyways, it’s getting patched.
“They originally added code that only userdebug devices can install (userdebug is what’s usually used during testing vs regular user builds).”
Tried the powershell route? Whaddya think?
whos they
I’m assuming qin
On the stock builds, this is the error you get. Dunno why changing what he changed did that though.
I must’ve missed something.
not sure - works for me though
Didn’t you remove adb from /system/bin?
Nope
Temporary fix:
Change this in the build.prop and adb install will work.
ro.build.type=userdebugro.debuggable=1ro.secure=1
I can just add this to the exe permanently, but I’d rather take a look at services.jar, for the meantime.
I’ll probably add it temporarily
Update
Added it to the powershell and exe install method. ADB install works. Will work on actually fixing services.jar a different time.
Run the command or download the zip with the exe and you’re good.
Update 2
Man, this really a rollercoaster. I’ve confirmed a bug with the new services.jar…
Volume shortcuts do not work anymore… Time for me to take a break for a while.
Pretty sure I fixed all issues. Will upload soon when I’m sure and then turn the instructions into a full guide.
- ADB install working without any hacks
- Volume shortcuts exactly the same as before
- Apps not getting killed
The issue was that the services.jar that was patched had allot more than just the apps not getting killed part.
Update
All updated, the irm command and zip download should be all good.
Still waiting on confirmation that I did is alright, then I’ll make a full normal post.
the drive link is to the old services.jar that has the volume issues
Whoops. Will remove now and decompile 1.1.1 later too be sure.
