will doing this still keep the original bands or will it remove them and replace them with the usa ones
replace
how do you backup your files with out twrp?
You can pull userdata with dd or mtkclient
can some one make a guide how to flash us bands with out twrp?
Just flash stock boot img after and you will be back to normal no biggie
Twrp lives in the 1.1.1 boot.img
Skip the whole twrp thing, as long as your bootloader is fully unlocked and your have brom mode u can flash the bands with SPFLASH tool.
Sn write tool is important for the IMEI but has nothing to do with the U.S. bands
Only thing is, writing IMEI with snwriter does not always work on stock firmware.
As @Zvi_Wolf lol, he’s been having a “blast” haha
If I understand correctly,
The steps are to flash these partitions
nvcfg
nvdata
nvram
md1img_a
And then rewrite the imei, so you do I need to backup the partitions at all? And you not use fastboot (which is the easiest)
Nice good work thanks @TripleU for making our forum/community great!!!
@admins why do I need approval in this thread?
I think because it’s in the guide section.
Ok maybe remove it @TripleU ?!?!
done
not sure what the problem is. gimmie a moment
fixed
Yay thanks!!
Edit: confirmedđź¤
Naa, why do you say so? Flashing a f21 with the us bands will not replace it’s original bands, will just be added.
So why doesn’t it work in israel your wrong
