Flashing bands on Qin F21
Hello,
I flashed the @AIV American kosher ROM and after that I wanted to add American bands, and I saw that I couldn’t open the bootloader Because it’s blocked in this version, so I did the short process of flashing the partitions with SP FLASH and after that I rewrote the IMEI, and the device is stuck in BETA MODE, what to do now and how to install American bands and also the kosher ROM?
It should be noted that I can’t flash the kosher ROM before the bands because after that I can’t open the bootloader,
Thanks to all the helpers.
Google Translate… :joy:
Sorry to write again
The device is in loop and I need to fix it.
The device is not mine… :sleepy_face:
Anyone know why it gets stuck on Downloading DA when trying to flash bands with SP Flash Tool?
Use fastboot
Now when I turn on the phone I get a dm verity corruption error on boot and it just keeps rebooting
I’m assuming you unlocked the bootloader.
Flash this vbmeta_a via mtkclient or fastboot. It will boot.
https://raw.githubusercontent.com/AlikornSause/Notes-on-QIN-F21-PRO/refs/heads/main/vbmeta_a.bin
Yeah bootloader is unlocked
I just just do fastboot flash vbmeta or it needs any flags?
I didn’t use any flags. I know forsure mtkclient works.
Just tried, still having the issue
What did you do exactly? Also, what firmware are you on
Try flashing the super again
I have a quick question
How can I enjoy both American bands and @AIV’s kosher ROM?
Flash the bands then kosher rom
The bands won’t be deleted?
Check what is flashing make sure those partitions are not in there and being flashed
Thanks @admins for moving it
This is the partitions. Can I flash everything?
Or is there something that’s a problem for bands?
list
_Android_info.txt
boot_a.img
device.txt
dtbo_a.img
Ik_a.bin
logo.bin
md1rom_a.img
MT6761_Android_scatter.txt
preloader.bin
spmfw_a.img
sspm_a.img
super.img
tinysys-scp_a.bin
tz_a.img
userdata.img
vbmeta_a.img
vbmeta_system_a.img
vbmeta_vendor_a.img
Do not flash preloader
Good catch! So now I got it to flash but I still get dm verity error
Do a full reflash everything of 1.1.1
