i flashed the phone not sure about the bands and the sn write tool part?
Followed all the instructions?
yes
i forgot write down my imei so i am useing the one that is on the back of the phone is that the same one the phone came with?
Not sure then sorry
Not sure looking for a guide for the f22
loaded both apdb and mddb files?
if yes and it still doesn’t work,
- f21 restore - format + download
- re’unlock bootloader
- flash desired ROM
- flash bands
- sn writer or modem meta.
yes
When flashing us bands using the xda forum, only T-Mobile services works and only sometimes Verizon works. Is there any way to make verizon and at&t work properly?
Verizon- call and mention “CDMA-LESS PROVISIONING” “Feature 83856” to turn on.
Att works but frequently gets kicked off of network due to imei.
Switching to an AT&T IMEI would probably help
does this make it always work or only sometimes reliable?
always
ok thanks. and this will work with all services that use verizon or just regular verizon?
Actual Verizon and us mobile i can verify (although once in a while u get rep. that has no clue what ur talking about, just hang up and call again.)
Tracfone/total wireless, if the sim is activated already with CDMA-less it works if not they can’t really help.
ok thanks. but there is no way to just flash other bands to make it work like t-mobile?
No.
I was on US Mobile darkstar which is AT&t and I had a Verizon IMEI. didn’t have any issues
