any differences b
twn them
im still getting the same issue the only thing that does it for me is magisk props hide. does anyone know how i can do what magisk does without magisk so that i can be permanent i can flash the super to mukltiple devices
@sb123 I have a Qin F21 with US bands with US Mobile T-Mobile. overall it works pretty well but I do lose service here and there in certain places. Do you think adding that APN will help? Will adding it in any way risk / effect the service I have now?
You should he fine with the way it is.
If you’re APN is working working a different APN might only help with data speeds not stam service.
I have a qin from Israel version 2.0.8 how can I make it work in the us?
I flashed this bands and I have no service, I must also flash version 1.1.1?
IMEI? what about that?
Also changed it to a Verizon IMEI
then i have no clue.. sorry…
I’m sorry if this has already been discussed and I didn’t see it, but has anyone gotten the full US Bands working? I had an F30 Pro for a while and it worked perfectly in the US (rural areas as well) and then I flashed a few F21 Pros with the catstolethecrown guide but the coverage was horribly spotty…
Only bands 4/66 will work, the f21 doesn’t have the hardware for the other us bands to work.
I have it on a 3/32 that doesn’t make a difference
He meant those number bands I believe
Not the phone model
I meant lte bands 4/66 not the 4/64 model.
ive set up a lot of phones to work with us bands and they all seem with all the bands of the f30 to work verizon/tmobile/at&t
Ah i honestly thought that was a typo
I carry an exalt and a flashed f21 qin. They both have US Mobile Verizon. I notice here and there that my qin would lose service but my Exalt would still have. Apparently it isn’t the same.
not sure, but i would think you have to compare to an f30 since the hardawre is the same as oppose to the exalt that has differnt capbilities for receiving signal
