Don’t want to take them apart. Rather if someone has an old one, or a waterlogged one. - Or someone who doesn’t mind accidentally breaking something.
Anyone have experience with a Qin F21 Pro working with Verizon Network Extender? Know what would prevent it from connecting?
I’d assume it would have the same provisioning rules as a cell tower. Could be I’m wrong though.
Well, if the network extender does not contain bands four or 66 it will not extend the Verizon network for the Qin.
random question how do i install the sp flash tool and the sn write tool on my computer i can open it in the file and it works properly i just cant seem to remember how to install it on my computer? ive done it in the past its just been a while.
i know that this is not the topic now but it seems this is the right post to ask the question.
thanks
Just launch the .exe file
(And make sure you have the drivers included in that folder installed)
the folder thats called driver auto install exe only has the driver install application where are the other drivers that i need to install (if there is any) and where would i find the exe to install both programs?
just to be clear when i click on the flash tool.exe it only launches it doesnt install on my computer.
maybe im missing some of the drivers can you send a link where i can find all the drivers? or maybe i dont have the updated one
Doesn’t need to install.
Just launch it.
well i want to install it
Portable program… Doesn’t need installation
can someone help me i reset a f21 pro and now its telling me this device isnt play certified
i really need help asap
Check the guide on XDA on how to make it play store certified
what xda im not familer if you can help me
what rom are you using
I have no idea I’m not so tech savvy
I don’t have any rom on my phone it’s telling me this after I reset phone
in the about device section in setting what is the build number and other specs there.
I have flashed my phone into US bands but Verizon US Mobile doesn’t work Do you have a solution for it?
