Ok, so I got a new TIQ Mini M5 after reading here that it is similiar to the Qin (which I love) but doesn’t suffer from band deficiencies here in the good old USofA. Right out of the box - (without ever even booting) I did a full mtkclient backup, because I am so responsible and smart. I then booted went straight to settings, enabled dev options, checked allow unlocking bootloader, installed magisk apk, pushed boot from mtkbackup, patched, pulled patched boot. Quickly jotted down IMEI and other unique identifiers, the rebooted to fastboot using the famous autobooter tool and ran fastboot flashing unlock. Hooray. Probably I should’ve taken care of vbmeta first, whatever. Point is i got this screen and now its stuck. Doesn’t respond to any keys! So much for my backup i can’t evenfigure out how to shut the thing off. The battery doesn’t come out, and the keys don’t respond. I am FROZEN in fastboot until at least shivasar bitammuz!
Here is the text of the image for any people reading this.
Unlock bootloader?
If you unlock the bootloader, you will be able to install custom operating system software on this phone.
A custom OS is not subject to the same testing as the original OS, and can cause your phone and installed applications to stop working properly.
To prevent unauthorized access to your personal data, unlocking the bootloader will also delete all personal data from your phone (a “factory data reset”).
Press the Volume UP/Down buttons to select Yes or No.
Right now I’m waiting for the battery to bleed out… if anyone has a better idea, or ever took one apart and knows how to replace/disconnect the battery, please lmk. It can probably last a week on a full charge in fastboot mode…
tried all these. I guess I’ll try a VERY VERY LONG PRESS, and if not, i’ll go with @PleaseSmileToday 's light idea.
UPDATE: Hey @ars18, 10 full seconds did the trick! #FreezerOpensEarly
But if you said that you already did it for a VERY VERY VERY long time and then after holding for 10 seconds it did work then these 23 minutes must have been an eternity.
yeah, i got the tiq bite.
I forgot to mention, I had already done python mtk.py da seccfg unlock, which is most likely why fastboot froze up when i spazzedly (is that even a word?) decided to also run fastboot flashing unlock.
