How can I get an f21 that works in America?
I have no idea what bands are. I dont know how this works at all. Its just a simple question:
If I want to buy a qin (F21) to use in the US, how do I do that? The ones on Ali Express seem to only work on china.
Thanks
If you bring it to your local tech repair store they can swap it for you
Is it hard to flash your own bands, whatever that means? Does anyone sell ready from america?
i have a link to send but i can’t send links yet this place sells us ones
Thanks. Can you try pasting the link without https:// and a space instaed of the . - like google com
Qin F21 pro T-Mobile US Version 4GB 64GB phone – Qin Smart Phone i just got bumbed althouh at the moment they are out of the black one now
Oof its much more expensive than the stock one. Does anyone have any experience flashing bands?
Thanks @Coke
@coke Welcome!!!
@coke Think before you answer
When you buy qin f21 it will come with stock bands, you need to flash american bands
The easiest way is to flash @ars18’s rom (6.1.3) because it is included with american bands
I just do a full format all + download?
No
You flash it with a bat file (attached in the ROM folder) in fastboot mode
Wow thanks @The-curious !
Will try soon
Great reviews too… :sweat_smile:
Do you have a device already just without the us bands?
No, but I plan on ordering. Prob from ali express
You have to be very careful when buyings qins from ali these days not all of them are able to be flashed (most new ones can’t) you have to confirm with the seller that the charging port isn’t red and that the serial number doesn’t start with F21PMQC25
Wow thanks for the tip. Very informative lol
good to know. if you or someone else can post directly, links or name the seller pages to buy from, would be super helpful.
read more here PLEASE HELP With New Version of the Qin F21, Different Hardware and ROM - #932 by Meir
More here Qin F21 PRO Ultimate Guide
I’m looking for a seller for you, are you looking for a 32gb 3gb ram or the 64gb 4gb ram?
