How to Disable Background Data for Specific Apps
Prevent apps from using data in the background to save battery and bandwidth.
Method 1: Disable Background Data in Android Settings
  1. Open Settings > Apps.
  2. Select the app you want to restrict.
  3. Go to Mobile Data & Wi-Fi.
  4. Toggle Background Data to Off.
Method 2: Use ADB to Block Background Data
If your phone doesn’t have an option to disable background data, use ADB:
Step 1: Find the App Package Name
adb shell pm list packages | grep appname
Example: package:com.facebook.katana
Step 2: Restrict Background Data
adb shell cmd netpolicy add restrict-background com.facebook.katana
Step 3: Verify the Setting
adb shell cmd netpolicy list restrict-background
This will show a list of apps with background data blocked.
Method 3: Use a Firewall App
Apps like NetGuard or AFWall+ can block background data without ADB.
Notes
  • Some apps may override this setting when opened. A firewall is the best solution for complete control.
  • If an app stops working, re-enable data using: adb shell cmd netpolicy remove restrict-background com.facebook.katana
I hope this helps!
