This guide will walk you through installing and activating eGate on your Android device using ADB.
What You’ll Need
- Android Device: Running Android 6.0 or later.
- eGate APK: Download the latest version from the GitHub repository.
- ADB Tools:
- Install platform-tools on your computer, or use a browser-based ADB tool like WebADB.
- Activation License Key: Purchase from PayHip or use one you got from a reseller.
- USB Debugging Enabled:
- Enable Developer Options on your device by going to:
- Settings > About Phone > Tap “Build Number” 7 times.
- Enable USB Debugging in Developer Options.
Installation Steps
Step 1: Install the APK via ADB
Option 1: Local ADB Installation
- Connect your Android device to your computer via USB.
- Open a terminal/command prompt on your computer and navigate to the folder containing ADB tools.
- Place the eGate APK in the same folder for easier access.
- Run the following command to install the APK:
Replaceadb install app-general-release.apkapp-general-release.apkwith the exact name of the APK file.
If this is the first time you are connecting this device to your computer, a popup may come up on the device asking you to Allow permission. Press allow and run the command again.
Option 2: Install via WebADB
- Go to WebADB in your browser.
- Connect your Android device via USB or Wi-Fi following the on-screen instructions.
- Select the Install APK option, upload the eGate APK file, and install it.
Step 2: Set eGate as the Device Owner
Ensure the eGate app is installed.
Run the following command to set eGate as the device owner:
adb shell dpm set-device-owner com.oss.egate/.aIf the device is the LG Classic, run the following ADB command instead:
dpm set-device-owner com.android.cts.egate/com.oss.egate.a
This grants the app device management permissions, necessary for full functionality.
Read more about setting the device owner and how to fix issues setting the device owner at this topic I wrote:
https://www.jtechforums.org/t/setting-the-device-owner-information/674?u=donbot
Step 3: Grant Accessibility Permissions
- To allow eGate to set some features like blocking WebView and other app-related settings, run this ADB command:
adb shell pm grant com.oss.egate android.permission.WRITE_SECURE_SETTINGS
Step 4: Activate the App
- Open the eGate app on your device.
- Enter the license key you received at the time of purchase.
Step 5: Configure eGate Settings
View all the settings and what each does at this topic that I wrote:
https://www.jtechforums.org/t/egate-settings-explained/679?u=donbot
I hope this helps you installing eGate! Feel free to let me know if any modifications/changes should be made to add/correct information.
