How to set Device Owner via ADB on Meta Quest without losing Developer Mode?
Hi friends,
I am trying to provision a Meta Quest headset with a custom MDM (SecureGuard) by setting it as the Device Owner via ADB.
The Goal: Run the command: adb shell dpm set-device-owner com.secureguard.mdm/.SecureGuardDeviceAdminReceiver
The Problem: The command fails with java.lang.IllegalStateException: Not allowed to set the device owner because there are already some accounts on the device.
The Paradox:
  1. To set a Device Owner, I must remove all accounts (Meta/Oculus/Horizon).
  2. To have ADB access to run the command, Developer Mode must be enabled.
  3. On Meta Quest, Developer Mode requires a Meta account to be logged in.
What I have tried:
  1. pm clear or pm disable-user on com.oculus.horizon → Failed (SecurityException: Protected Package).
  2. Trying to open native Android Settings via am start to remove accounts manually → Failed (Permission Denial).
  3. Using Activity Launcher to access Settings$AccountsActivity → The specific activities crash or refuse to open.
My Question: Is there a known workaround or a “race condition” script that allows removing the primary Meta account while keeping the ADB session alive long enough to set the Device Owner? Or is there a specific intent/activity I can launch to remove accounts without killing the ADB session immediately?
Any help would be appreciated!
סליחה אם זה לא מספיק ברור כי זה מתורגם
oof… did not know that is a cause. try pm disable-user -- user 0
If I understood correctly, you wrote that I would try the command adb shell pm disable-user --user 0 com.oculus.horizon or adb shell pm disable-user --user 0
Both of them don’t work
Interesting dilemma.
Can you run termux on this device?
Edit - never mind, termux would probably not have enough permissions
Check this out
This app removes accounts from within the app. I think it’s for your device? If it works you can just disregard the rest of their instructions.
Try this, it’s what oculess uses:
com.android.settings.Settings$AccountDashboardActivity
First of all, thank you very much
I reset the device now trying to install Oculus and trying to progress
C:\\Users\\user\\Downloads\\platform-tools-latest-windows\\platform-tools>adb shell am start -n com.android.settings/com.android.settings.Settings$AccountDashboardActivity
Starting: Intent { cmp=com.android.settings/.Settings }
Exception occurred while executing ‘start’:
java.lang.SecurityException: Permission Denial: starting Intent { flg=0x10000000 cmp=com.android.settings/.Settings } from null (pid=30610, uid=2000) not exported from uid 1000
at com.android.server.wm.ActivityTaskSupervisor.checkStartAnyActivityPermission(ActivityTaskSupervisor.java:1197)
at com.android.server.wm.ActivityStarter.executeRequest(ActivityStarter.java:1113)
at com.android.server.wm.ActivityStarter.execute(ActivityStarter.java:768)
at com.android.server.wm.ActivityTaskManagerService.startActivityAsUser(ActivityTaskManagerService.java:1295)
at com.android.server.wm.ActivityTaskManagerService.startActivityAsUser(ActivityTaskManagerService.java:1246)
at com.android.server.am.ActivityManagerService.startActivityAsUserWithFeature(ActivityManagerService.java:3321)
at com.android.server.am.ActivityManagerShellCommand.runStartActivity(ActivityManagerShellCommand.java:728)
at com.android.server.am.ActivityManagerShellCommand.onCommand(ActivityManagerShellCommand.java:235)
at com.android.modules.utils.BasicShellCommandHandler.exec(BasicShellCommandHandler.java:97)
at android.os.ShellCommand.exec(ShellCommand.java:40)
at com.android.server.am.ActivityManagerService.onShellCommand(ActivityManagerService.java:10160)
at android.os.Binder.shellCommand(Binder.java:1093)
at android.os.Binder.onTransact(Binder.java:913)
at android.app.IActivityManager$Stub.onTransact(IActivityManager.java:5436)
at com.android.server.am.ActivityManagerService.onTransact(ActivityManagerService.java:2793)
at android.os.Binder.execTransactInternal(Binder.java:1369)
at android.os.Binder.execTransact(Binder.java:1300)
C:\\Users\\user\\Downloads\\platform-tools-latest-windows\\platform-tools>adb shell am start -n “com.android.settings/com.android.settings.Settings$AccountDashboardActivity”
java.lang.SecurityException: Permission Denial: starting Intent { flg=0x10000000 cmp=com.android.settings/.Settings } from null (pid=30777, uid=2000) not exported from uid 1000
Try this
adb shell am start -n com.android.settings/com.android.settings.Settings\$AccountDashboardActivity
And this
adb shell "am start -n 'com.android.settings/com.android.settings.Settings\$AccountDashboardActivity'"
C:\Users\user\Downloads\platform-tools-latest-windows\platform-tools>adb shell am start -n com.android.settings/com.android.settings.Settings$AccountDashboardActivity
Starting: Intent { cmp=com.android.settings/.Settings$AccountDashboardActivity }
C:\Users\user\Downloads\platform-tools-latest-windows\platform-tools>adb shell “am start -n ‘com.android.settings/com.android.settings.Settings$AccountDashboardActivity’”
Error type 3
Error: Activity class {com.android.settings/com.android.settings.Settings$AccountDashboardActivity} does not exist.
The first one opened the screen for me like in the attached picture and the second one did nothing.
@TripleU By the way, notice which app is open below.:musical_notes: :face_with_raised_eyebrow:
I’m sorry I don’t know
Anyway, thanks for the help.
Oculus did nothing?
Oculus also opened that screen
Sorry
Is there a way to maybe flash the firmware?
Then configure it
If it goes into download mode is it possible to flash?
How can I try to flash without taking a risk on the device
Can you pull the settings APK with adb?
מה הפקודה אני ינסה
adb shell pm path com.android.settings
# copy the path
adb pull /path/to/settings.apk
Then upload somewhere and send me a link
No guarantees but I’ll try
