Learn how to use ADB wirelessly to connect to your Android device without needing a USB cable.
Why Use Wireless ADB?
- No need to connect via USB
- More convenient for debugging
- Works with both rooted and non-rooted devices
Step 1: Enable Wireless ADB on Your Phone
1. Connect your phone via USB (only required for setup).
2. Run: `adb tcpip 5555`
This restarts ADB in TCP mode.
Step 2: Find Your Device’s IP Address
On your phone, go to:
Settings > About Phone > Status > IP Address
or run: adb shell ifconfig wlan0
Example output: inet addr:192.168.1.101
This means your phone’s IP is 192.168.1.101.
Step 3: Connect to ADB Wirelessly
On your PC, run: adb connect 192.168.1.101:5555
Step 4: Verify Connection
Check if your device is connected: adb devices
You should see:
192.168.1.101:5555 device
Note:
- If ADB disconnects, reconnect with:
adb connect <your_ip>:5555
To disable wireless debugging, restart your phone.
