Israel 2G/3G shutdown - U.S 4G/5G Phones For Eretz Yisroel
It’s fairly simple. There are three options either an app, magisk module or script. If you can install apps download the app and when you open it it will ask for superuser permissions, enable and within a couple seconds it will activate and delete itself. The module is like any other magisk module. I never tried the script
What about to build it into my rom?
download app https://mitmachim.top/assets/uploads/files/1763496919275-voltepatcherv5.zip
module https://mitmachim.top/assets/uploads/files/1764887867635-kosher-volte-module-confv3-fixed.zip
this should work for you מדריך | מדריך להפעלת וולטה ע"י Patching של המחיצות וצריבה - ללא צורך ברוט (טוב לגירסאות חסומות להתקנות) | מתמחים טופ - פורום הטכנולוגיה של הציבור החרדי just use google translate and you’ll get the general idea
I don’t really trust google translate can you make a guide in english
@anonymousfliphones
I wrote this quickly
I would appreciate it if someone would edit it
Can you add this מדריך | מדריך להפעלת וולטה ע"י Patching של המחיצות וצריבה - ללא צורך ברוט (טוב לגירסאות חסומות להתקנות) | מתמחים טופ - פורום הטכנולוגיה של הציבור החרדי he wanted to add it a ROM and I think this is the easiest? Otherwise looks good
So is the Israel 3g shutdown official today?
my tcl is still working here. (doesn’t support 4g israeli bands.)
Heard of much people using cadence that it’s not working anymore. Other than that think everything else still working.
Same
This picture is misleading, cat s22 doesn’t work with VoLTE in Israel and the wonder phone works in Israel Yes I tested myself
Hot mobile is not allowing new 3g lines for almost 3 years already
CAT S22 has the right bands for Israel so its not wrong. As for the wonder phone, how long did you use it in Israel?
Just confirmed CAT S22 works with VoLTE in eretz
Has the bands, for some reason VoLTE doesn’t work if 3g goes down phone calls are not gonna work
So the wonder won’t work on roaming either. Right?
Wonder never had the old network bands to begin with :joy:
It has one not very commonly used israeli LTE band so you might see some LTE but still very unreliable
Kyocera E4810 and E4811 are still working
Is it confirmed that the TCL’s dont work in israel?
Calls and internet not working
But messages do work
