KaiOS Style Launcher for Android Dumbphones
Here is an android launcher I made modeled after kaiOS.
Screenshots
It still has some rough edges and needs polishing off, but overall this is the most complete launcher we have for Android flip phones.
Definitely deserves its own topic.
Thank you! I’m glad you like it! Please let me know what I can change, I no longer have a KaiOS phone so I’ve done most from memory and screenshots online (few exist).
If anyone could send screenshots from KaiOS that’d be amazing! Also, I’m trying to locate more KaiOS app icons so I can add them to the theme as well.
I’m looking for people to submit lists of app IDs for default apps on their Android devices so I can have them be themed to KaiOS when applied by the user all in one go.
I plan on making “ports” of other apps and functionalities if anyone would appreciate that.
That’s not a big issue, you can get one for less then $20 if you want cause nobody wants to buy a KaiOS phone :joy:
I have a KaiOS phone so later this week i’ll try sending some screenshots
I tested it on my Kyocera DuraXe e4830, it’s very good.
I think it’s the first one I tried that integrates the dialer in the way it should be.
Some things that should be fixed:
  • The button to open the main menu should be highlighted by default every time you go to the home screen, that’s how it is on all phones and how people expect it to behave
  • Pressing the left and right buttons shouldn’t highlight the soft keys (like notifications and contacts), that’s what the physical soft keys are for
  • On my phone when dialing, the first digit is entered twice
  • In the main menu, when I get to the end of a row, pressing right should make it jump to the beginning of the next row
  • The left soft key should also be customizable
Just tested it on the Schok Classic, works excellent but in the next release, try making the apps list go more then 3 lines cause it looks weird
What’s your screen resolution? For me it shows 5 apps on the home screen. My resolution is 400x300. Can you send a screenshot?
EDIT: I will upload new APK soon with better scaling for more devices on the Home Screen.
Do you mean like a larger grid in the app grid list instead of 3x3?
notifications don’t work either
There aren’t notification dots in this version, only the counter on the home screen. I’ll get those out in alpha 3 tonight or tomorrow.
Would you like it to have 4 rows when the screen is taller?
All of these should be fixed on the latest build.
I am just happy to see more DPAD apps. Good stuff.
Beautiful, the app is a lot more usable now, and is already better than most dumbphones stock launcher.
Some tweaks it still needs:
  • In main menu, left soft key should scroll through pages.
    You don’t need to have a soft key to exit the menu, all phones have a back or end key for that.
  • Uninstalling apps from the main menu isn’t working for me.
  • In launcher settings, scrolling down to the bottom shouldn’t highlight the select button, most phones have a center key for that.
  • Switching the toggleable options makes them lose focus, that shouldn’t happen.
  • The app could use a more uniform UI.
  • The app list on the home screen should be partially hidden when it’s not selected.
  • Pressing back should close it.
@PodLP reverse engineered the proprietary APIs of a bunch of flip phones, allowing his app to integrate with their navigation bars, native dialogs, and other system components.
It’s a major enhancement for any dumbphone app, especially one as a prominent as a launcher.
Maybe try getting the code for it from him.
Try this build lmk how it works, I rewrote the app icon sizing and grid functionality.
