List of phones tested with carriers
Post all phones (non smartphones/basic phones) that you have tested with service carriers here. Remember to list what features works and what doesn’t work. Try including exact phone model and also try to put a few phones in one post so it keeps it easier to read
qin f21 pro works with verizon ONLY WITH CDMA LESS ACTIVATED not able to receive videos and voice notes besides using rcs and works fine with t-mobile
kyocera e4811 works with all carriers that i tested (verizon,att,t-mobile) just make sure apn is set correctly
tcl flip 2 unlocked works well with verizon works withh att but people report data issues
pls someone reply this way i can post more locked with the 3 replys in a row restriction
List of phones I tested
LG Exalt Vn220
Verizon - :check_mark:
Visible - :check_mark: Only Hotspot doesn’t work
Schok Flip SC3218T (2022 Version)
AT&T/Consumer Cellular - :check_mark:
Visible - :cross_mark: Calls and Texts didn’t work at all, data and hotspot did work interestingly
Schok Classic SC3218 (2020)
H20 - :check_mark: Only issue I ran into was I couldn’t put a call on hold
TCL Flip 2
H20 - :check_mark:
Annoying thing doesn’t wanna erase, so just ignore it
Kyocera Cadence
AT&T - :cross_mark:
Now this doesn’t wanna delete either!!
kyocera dura xe epic works well with att and t mobile when carrier unlocked
tiq mini m5 same as verizon but i found that it works really well with att (my preffered network)
i have a qin and i called verizon multiple times and most didnt know what cdma-less was and others said the imei is incompatible and gemini claims that a while ago verizon started moving off cdma and all accounts by default have cdma-less activiated so……….
Idk this is my experience with over 30 devices more than that I can tell you anything
They won’t help u with a invalid imei, u can tell them to turn on CDMA-less when ur SIM is in a good Verizon imei phone, then swap the SIM to the qin after.
If they don’t know what it is tell them to turn on “feature # 83856”
Sonim xp3800 verizon t-mobile
Sonim xp3900 Verizon t-mobile
depends what model. sonim xp3800 and xp5800 that were locked to at&t or T-Mobile won’t work with verizon (or any verizon MNVO) even after unlocked.
(in my experience calling basically never works, messaging takes years and data turns on and off. its longer off then on)
does at@t work on qin
Works for me….
Had to contact them but in the end it worked
did you change the imei
Yes, to one from the tcl flip.
Anyone tested LG exalt with AT&T and T-Mobile?
