Anybody know of any way to remove apps or install an MDM on newer GM vehicles with Android? I can turn on usb debugging and it shows in ADB devices but says You need GM Secure ADB client to establish a secure ADB session. if I try any adb commands. I couldn’t find a “GM Secure ADB client” any other way to connect?
Are you able to install apps? Not via adb but normal
No didn’t figure out how. I installed a file manager from the play store but it wouldn’t install apks. The selection of apps on the Play Store is limited so I can’t just install anything.
Don’t know that I want to go this deep though and looks like any updates would relock it.
