MB Smart Filter
I did not say content blocking
I said content filtering
Let’s explain it very clearly
On mb PRO if you go on amazon on the kiwi browser you will get content filtering (real time filtering/text filtering/image filtering you name it)
But if you will goto amazon on the chrome browser (or any other one that does not support extensions) there will be no image filtering (= content filtering)
So you also have this same problem with gentech? Do u have an alternative?
No
Because gentech is a proxy based filter
Mb smart is the only filter that uses an extension for content filtering and that is one of the reasons why it works faster
Gentech does not do image filtering so i don’t care how it runs you still have the same issue
Of course they do
Where can i get mb smart for a qin?
You’re asking that in the wrong place.
On this forum, the answer is drumroll, please… :drum:
eGate :stuck_out_tongue_winking_eye:.
Correct they can only block Google images on the search page but personally I used to have image blocking on my laptop I removed it because its not great
And tag does not give it out
Correct, that’s why I’m asking
I got it privately from a friend and I don’t know anyone that would be willing to put it on a random guy…I once heard tag Flatbush but I can’t confirm…
There is a mb smart installer.exe somewhere online. I’ll see if I could find it
But then i think you need an activation key
On the forums…
Where
Who are you talking about regarding the google images
And which filter do you have on the laptop?
maybe it got deleted
I found your post on mitmachim
