Someone brought me a new Kyocera e4610 phone
and he wants to block the browser and email and hotspot
and also install Waze and Moovit etc
Can someone explain to me what the possibilities are?
Adb non-filter
It doesn’t want ADB
Is there an MDM that works on this device?
Can I install regular apps on this device or do I need a custom app?
OldMDM.
Can I install APK files on this phone?
I also need an app launcher because I don’t see it on the home screen
Yes.
There are a bunch of launchers, go through Uploaded Apps Thread.
Use egate.
Does that work on the e4810?
Does that mdm allow app installs? Or is that a toggle option which you can allow?
I don’t think so…
What’s the point of it if you’re allowing app installs?
I guess for that price i can block with adb. Good point. unless there’s an option to block installs without a code or alike.
If that’s true then I would install apps first.
What is the most recommended?
There are several types
This one is amazing.
Can hotspot and Wi-Fi be blocked on the E4610 with ADB?
