Does anyone have a working version of message plus that works well with the D-PAD on the Kyocera E4180?
Same Message+ app that the other two older kyocera’s have. Some features might not work right but for text messaging it will work
I tried installing but it crashes right when I open it.
You have to set it as the default messaging app then it will stop crashing. Maybe even disable (not uninstall) the original messaging app if it still crashes
@Felzy please confirm if sending it as default messaging app helped. Thanks
yes
