Messaging App to Work With D-pad
I don’t know if @FlipAdmin is working with the source code of Fossify’s messaging app or modding the apk, but if he’s working with the source code it might make more sense to try to add profile spoofing to Fossify’s messaging than to mod Handcent SMS.
Either way would be amazing
I’m working with the source code.
Is it possible to add in mms profile spoofing?
I don’t know. I’ll post the code to GitHub.
Then would you be able to edit the handcend next sms app to make it work with the dpad
The app works great, but its scaled too big.
Can you fix that?
Trying to use google messages (an older version found on apps4flip forums) on Kyocera E4810. When sending an MMS it says there is a network issue. When using the regular messaging app it works perfectly. Is this the same protocol issue mentioned above?
Probably not the protocol issue on the Kyocera extreme 4810
It’s most probably that Google messages can’t properly access all the phone features.
Where is the Github source code repo for this branch?
Making it a community project:
would this also work with verizon?
Thanks @FlipAdmin, really appreciate your work going on here.
Where do you suggest or prefer that we post issues and ideas, here or on Github?
If its done here, should we possibly create a new thread just for the app?
Do it on Github.
This is a Messaging app that I took off a flip phone with no touch screen, but it crash’s when you try to open it, I’m hoping someone can modify it to work because I tried already, this is a nice clean messaging app that works entirely on android phones without touch controls
Which phone?
Schok Flip
I think I finally found a messaging app that’s 95% d-pad compatible.
It’s FOSS.
Anyone want to start a project to finish up that last 5%?
Mind sharing it here?
@Dev-in-the-BM_2.0 Which app do you currently use with the 3900?
I’m looking for a good one.
