I think I’m going to be switching servers. I already have quite a lot running on the first one (I maxed out RAM in fact) and would like to switch servers as seamlessly as possible. How can I do this
Haha good luck with that! It’s known as from the hardest stuff to do but it all comes down to your you configured it
#nixos
Just ask AI to list all the dependencies you have and then use the same server name so the file paths stay the same and just transfer the main fclder
Do you have an organized setup like with 1 language or just a big mess of different service?
If it’s messy and you have the time and patience I’d redo it. Great opportunity to make סדר of a mess ![]()
but what @Shalom_Karr said about directory name… Is definitely an easy way (though I wouldn’t use AI for the other part)
I really don’t remember everything so I’m having it go through all my logs and make a list of everything I have to do
You mean username, right?
Dis why you use docker ![]()
