I recently rooted my tiq phone and would like to play around a bit.
Android 13 won’t allow read/write permissions so I need to use modules.
What are the steps to create such a module that I can edit the build.prop and then install the module and have the change done systemlessly?
ars18
2
Don’t use modules for services.jar, most likely bootloop from all that I’ve tried.
Rather back up original, then make sure adb on and authorized. If it doesn’t boot, you should still have adb in my experience.
ars18
3
Oh whoops… R/W
It’s funny, I’ve actually been successful on a13 ROM on the tiq… But not normal stock.
Looks like this is what I was looking for:
