Hi im trying to use the pointer that @sh7411usa uploaded here Uploaded Apps Thread - #40 by sh7411usa
i installed on a TCL using the -g flag i also had to enable in the accessibility app.
but i cant actually click on anything. i have a notification saying the pointer is displaying over other apps… and when i open the notification it says “Draw Over Other Apps” feature not available.
when i open the pointer app it says pointer service: inactive.
please advise how to get this operational. thanks
Old problem tcl is android 11 and virtual mouse doesn’t work to click on android 11 devices u could either use the vmouse2 module from neutronscott on github or c9 app with shizuku from @wheredidmysleepgo C9 - Android Cursor Alternative pt. 2
This module is great as well: FlipMouse Module: New Mouse for the TCL Flip 2
This one allows you to type while using the mouse.
Does it work to press end to close the mouse? i liked neutron better how do they compare? i never really used that one before.
Pressing end will not shut off the mouse.
