Here’s my other phone that looks like the quin of 21 pro this has the same screen size and the same specs 3 gigs over 32 gigs of RAM touch screen will be made most probably kosher and it will be priced at a budget price for most people at $200. It has two SIM cards and a memory card slot that can be used for internal memory so instead of 32 gigs you can add 128 GB SD card and your phone becomes internally 160 gigs. Tested to work in the USA I will put some screenshots up
And battery is removable
