Otzer Hachochma Filter
I made a filter that you set it up using a couple ps1 scripts and it locks down an account for an Otzer Hachochma kiosk
Good idea!
I usually do that with MMC > add snap-in > GPO.
Set SRP to block all, and add only the path I want to allow, with a Logon script that opens the intended program. (mostly DW spectrum for a camera user.)
SRP won’t work anymore cuz SRP was deprecated and it no longer reliably enforces.
So basically building a kiosk on SRP is building on something Microsoft has already gutted.
I am working on the same concept now just for a Torah Anytime Device
Is it compatible with Windows 10 Pro?
It should be - if its not then open a pr or issue - test it
