Flip phone.
Android Go.
Not so good camera.
Heavyweight.
Has a play store.
Touchscreen.
Works with T-Mobile out of the box. AT&T I am not sure. Verizon, there is a guide out there to get it working. Make sure you buy an unlocked one if you are not using T-Mobile.
Actually prefer side load. I don’t want it super easy to install apps, just possible in the event of life needing something.
That is my current phone, its worn out and I am researching my options. Its not the worst, I actually like it a lot.
The reason for the questioning, I have seen the Wonder and the Fig, and they are great, its just that they are to limited for my purposes. I need a few more app options. I especially like the large display and camera.
I haven’t seen it before, thanks for the mention. I will look into it.
Very easy btw and confirmed working. I did it. Very easy. Looks threatening, but that guy just says every single and possible step… I was surprised he did not tell me like to eat something if I was hungry during the process…
Good suggestion there, I may have to try that. Its probably the best I’ve seen.
I may also just get two phones, that way I can have a Wonder phone for daily use, then another phone with my apps on. It would be highly expensive though. I might see if I can find a Chinese company to build me a similar phone, and have more options available. I think there would be a really good market for selling something like that, especially to the GenZ crowd who is looking for a simpler phone, but also wants some options.
Has anyone on here seen the https://minimalcompany.com/? I really like the idea, minimal phone, eInk display, but basic Android functionality. The screen is complete black and white.
